I was not happy with the way the feet sat in the bed of my truck so I designed these plates to be mounting to the bed first. Thought I would see if anyone else was interested in a set... Was thinking the plates would be around $100 for a set. I had to get $25 worth of hardware to install as well.
The plate is 0.500" aluminum that is water jet cut. The standard mounting holes are aligned in the plate and then drilled and tapped 1/4-20. The plate is carriage bolted permanently to the truck.
The plate spreads the load out and really allows to use the adjustment bolts to crank the deck up and down.
