...and frustrated as %&*#$$#%&!!
I was out riding my cruiser ('05 edge 800 touring), put on about 35 miles and the engine started making a funny noise. I stopped to figure out what it was, but couldn't find anything, so I swapped in another set of plugs and turned around to head for home.
When I got home, I snapped this:
(view full size here) http://s473.photobucket.com/albums/rr97/uglykid555/sled tech/?action=view¤t=01-10-10010.jpg
The plugs on the right have about 150 miles, the plugs on the left have 10 miles.
I cleaned the carbs,
checked seals and boots for air leaks with starting fluid, (no leaks)
did a compression test, (135 per hole)
checked the reeds, (they're fine)
changed the fuel, (fresh 93 non-methanol to replace the old 93 non-methanol)
verified the oil pump and fuel pump were both working ok,
checked the TPS, (10k to 50k ohms progressive both sides)
verified no coolant leaks,
verified no exhaust leaks,
pulled the exhaust and looked at the pistons (which were perfect, still shiny, and had a slight coating of oil) and the piston tops (which were black and showed no signs of damage)
then I cleaned the carbs again,
went through 3 more sets of plugs in the process,
Today, I put on about 4 miles, and here's the plugs afterward:
WTF? What am I overlooking?
