Does anybody experience trenching? I have a 16' MHLT on a 2010 KTM 530 EXC with the TSS.
58 would be a good climber, 62 fun and playful on the flats. Tune that with the ball join on the bottom of the TSS and fork height in the triple clamps. You can use a angle gauge, avalanche slope gauge or a framing square to get close on the measurements.
Good luck tuning and dialing it in
How are you making the shock compress when you’re in 2-3’ deep powder with basically no base within reach? Wouldn’t the powder just keep giving out and compressing before that hundred lb spring does?
So you’re saying with properly set suspension, it’s possible to have virtually no trenching?
So you’re saying that a minuscule 2 degree angle in head rake is a night and day difference? Turns the bike from a single track beast to a high mark king? But then yet you say use a framing square to “get close”. GASP! What if he ends up at... dare I say, an unrideable 57.5 degrees!?!? If it makes that big of a difference and is so critical to the way the bike feels, isn’t it a “get it absolutely 100% accurate or dont do it all” type deals?
I don’t believe in all this hype of a degree making or breaking the bike. We’re far from pro and there’s so many variables that it can’t even really be tested properly IMO. Every snowfall is different and more or less dense which allows your ski to sink a 1/2” more than the day before. Would that not negate any head rake angles you made? How about rock stiff frozen fork oil for the first hour of riding vs the last hour? Anyone ever consider that? How about the Gatorade bottle on my front fender bag that gets drank throughout the day, adding less weight on the front end? How about body positioning and how far back on the seat you sit? Seems like those are all more significant than sliding your forks up or down a couple thousandths of an inch.
I just hope the op doesn’t think his trenching problems will completely go away if he changes his head angle. He will be awfully disappointed.
On the yeti you also have the 3 front arm mounting positions to play with. I tried the upper hole, but have gone back to the middle. When the snow gets hard the Yeti ski just fights back.. I am going to try an ARO ski to see how much that fights me in spring snow. Frozen trail + Yeti ski = no fun for me! As for trenching, softer front shock definetly helps. IMHO
Cory!!!! You are getting good info here. Yes, these minor adjustments do make a difference. The items you list definitely do play a factor but I've spent major time tuning my yeti with slight adjustments and can say that they can make a huge difference. Considering in a previous post you asked what the case vent line was I believe you have a fair amount to learn and should soak it up rather than calling it out. Seek wisdom grasshopper.
I’ve noticed those but havnt fiddled with them. But yeah, packed trails and crusty snow is torture on the ol forearms with my yeti ski. Definitely fighting it all day.
We all got a lot to learn. Me included. I got no problems admitting it and sometimes playing devils advocate to promote discussion and get some thought going. What does me being new to Ktm 4 strokes have to do with anything tough? Talk about irrelevant. Nice try though.
the springs you need are 1 7/8" inside diameter, front shock can use 8" length or 9" length and I use a 10" on the front that works fine.
on the back you have to keep the spring short to go between the rear scissor arm, 8" length for the back shock
