Trailer
F
Freakasnow
New member
Have a new enclosed 3 place and was wondering what is the best product to apply to the floor for protection. I know rino lining is good but not cheap at all Anyone have any luck with the DIY off the shelf brands of floor coatings? Or what about maybe the epoxy coating one might use for a garage floor you can pick up at like Home Depot?
Also what might I use for a vapor barrier on the walls and ceiling? I was going to apply a vapor barrier then either 1/4" plywood or White FRP panels.
Any input would be appreciated!
Edit/Delete Message
Edit/Delete Message
Edit/Delete Message
I used two coats of white latex gloss on the walls, and two coats of light gray oil based industrial enamel on the floor. I added some fine white silica sand over the wet second coat for non slip. The garage floor epoxy won't work over wood.
