Trailer sweat/condensation - please advise
Just wondering if anyone may have a suggestion on what I can do to the inside of my trailer (ceiling) to cut down on the condensation? It sweats so bad that it gets all my gear wet. It already has a vent in the roof that I leave open. Doesn't seem to do the trick. Most of the roof is aluminum. I have heard of some painting techniques that may help. Has anyone tried anything like that?
First are you running heaters inside of the trailer when its sweating all the time and second is it just a thin wall aluminum with no insulation?
Get some insulation in there with a vapor barrier. I also run Salem vents to help the air move through the trailer.
I use 1" styrafoam and fiberglss bathroom tile on the inside of mine. I did it more for the protection on the walls to prevent denting from the inside out, but it did help with the condensation as well.
Two things help to create the sweating. The first is moisture (snow brought in on the sleds) and the second is the differential of temp between inside & outside. You need to address both to cut way back on the condensation. For the moisture issue, when you get back home plug in a small electric heater in the trailer. You don't need to blast it on high, just enough to move and dry the air. Also, keep the vents cracked.
For the temp differential you need to remove what is known as "Thermal Bridging". This is anything that allows the outside and inside temps to directly react, such as the aluminum roof and framing. Like the others have said, insulation is the answer. Remember the framing, not just the roof sheets.
OK, so this is a long winded way to say heat and insulation:)
Just wondering what you are using to hold the insulation to the roof. I need to do my roof and was not sure if glue would hold it over time.
Hey WYO312, We used 1" styrofoam sheets, if you cut them to fit snug between the tubing you won't need glue. (Tried glue first, didn't work very well.) Then cover with the same type of siding that is on the walls. That's the plan anyway. Still working on it. I'll let you know how it turns out.
You can buy spray adhesive for 5 bucks a can.
Also and multiuse glue.
Make sure the glue you do buy can still adhere at low temperatures.
spray foam?
has anyone tried using cans of the expanding spray foam in the walls? Seems cheap and quick. I cant really sacrifice any inside space and foam seems to be the only way to insulate the walls without tearing open them open. I am going to do it in the ceiling as well. I will probably use 1" foam underneath attached with construction adhesive. I might put some tin over the foam just to protect it from road debris.
The key word is expanding. We use this on our projects quite regularly (carpenter in a can). When it kicks, it really expands. Be careful about spraying in an enclosed area, it will buckle the wall covering when it expands.
