Trailer heat
A
afrank3594
When I decided to heat my trailer I wanted to use forced air so I could dry things off and vent the exhaust outside so I don't kill myself . Im using a Suburban 35,000 BTU heater that is mounted flat on its side. I used a 2" pvc 90 deg for the intake air and a 2" exhaust pipe from a U bend . Thats 4" duct down the side to get the warm air to the back and yes the vents are small yard drains . The front wall has a 12 hour timer for the stereo and heater so I don't forget and leave it on for a couple of days. the shelf above the thermostat is for an Ipod or MP3 player. To the left is a cheap indoor/outdoor thermometer , below I have a volume control for the ipod , 12V plug to charge phones ,120V from the shore power inlet and my 12 hour timer . Its all made on a white board for writing notes on what to bring next time and what I forgot . I'm sure that Ill change things next year but for now all I need is snow
Nice
Nice looking setup the only problem I have run into is the ceiling will frost when I turn the heat off and go riding for the day. So in turn when I come back it will drip for an hour after turning the heat back on. Have you had any trouble with that?
I get a bit of frost but not bad enough that I worry about and I try and leave one of the vents cracked a bit. I keep thinking about adding insulation but that seems like a ton of work.
A little Sony amp that pulls very little power ( it has a 6.3 amp fuse ). I have a couple that I would sell if you want one . The tank is mounted in the front of the V
Mine is mounted on the inside in the "v" I know its not vented but I think that I will know if its getting to the LEL ( ill be the guy running from the snowpark) .
Springville Power
Work for a city owned power company, total of 9 linemen. Close to 20 years with springville. :cool:
peace-
johnny
