I just finished mounting my Atwood 8500 series in my enclosed. But, I did not do it the conventional way. Here's why:
That furnace was designed to be serviced from the outside. In the RV world, that is a major plus - it allows the furnace to be installed behind cabinets, and other hard to access areas, that would otherwise be unused space. Space in RVs is a premium.
But, being that I wanted to conserve my floor space in my 28' pace enclosed, I chose to mount my furnace up high, pretty close to the ceiling. The 'pancake' or 'flater' shape of that furnace, means it will hang down less than other, more traditional (read: old) designs. With this high-mount idea, it makes exterior-only access a definite bummer.
With that 'flat' design, it becomes wider. And, in my case, wider than the distance between two wall studs. This adds another fly in the ointment.
Also, I'm not a fan of the furnace components having access to the outside elements, especially in our sport, where that de-icer is getting kicked up in a spray type form and getting all over my stuff. That crud is hard on everything and that furnace wont like it none either.
So.... what did I do? I liked the shape of that flat furnace. And since servicing it from the inside in our application is a plus (I'd rather stand up inside my trailer to pull the furnace rather than be out in the weather and on a ladder) I riveted a few pieces of aluminum angle to the opening of the heater box, thereby creating a flange. I added some foam tape to the surface of my new flange, and mounted the furnace up against the inside of my trailer. I marked my location, drilled an exhaust hole, and then extended the exhaust tube, trimmed the excess of of the exhaust flange, riveted an insect screen on the outside of my exhaust flange, and then mounted it up.
On the inside of my trailer, I did re-locate the circuit breaker, so I have access to it from inside, and made a support for the back of the furnace to the ceiling.
It's still safe, because the exhaust if forced out the proper pipe (make sure to get the correct size, and make it extend the proper depth into the burn chamber), the air intake for the burn chamber does draw from inside the trailer, but a squirrel cage make sure the exhaust products don't make it back into the 'living space'. If the furnace gets a 'puff-back' or the fan stops working, the sail switch is normally open, it's a fail-safe design, so it shuts down the gas valve, and you're fine.
Now, all I have on the outside, is one, small chrome exhaust vent with a little dome-shaped screen over it. Puts out lots of heat, and my furnace is safely installed, and protected from the outside elements.
Send me a PM if you want pics.
PE
