TRACKS
9115m Camoplast Challenger Extreme Sawtooth. 16x3x174.
If you need a 15" wide, get tracks Usa to cut it for you. The paddles will go right to edge.
3.2 Camo doesn't work as well.
Remove every second clip, put the clips on the paddles ones only, replace approx 28 cuz that's how the #'s workout with guide clips/paddles. Cut off the rubber nubs on the inside.
Weight savings-3lbs x 7lbs rotating weight=21lbs!
Tracks Usa will do the clips but you gotta do the nubs. Oscillating knife blade with no teeth works well. 30% dish soap/70% water for lube.
You can port a little bit for another 1lb and it softens the track for more efficiency. Bdx sells a track porting tool.
If you wanna get brave and save another 1/2lb change the guide clips to flat clips. Not recommended though.
Sent from my SM-G920W8 using Tapatalk
