With all my buddies buying Turbo's and me too afraid to pull the pin on a turbo as well, I decided I will try my own thing to see if I can climb a little higher, and get stuck a little less often.
I decided to buy a 2.3" lug track, it's only available in 16" wide, so I had to cut it down to fit.
I wasn't able to flip the track inside out to make it easier, so we ended up putting the track on a table, and using a circular saw with a homebuilt fence strapped to it, so we could pick up on the edge of the track, and remove as much as we need to get down to the 12.5" overall width.
We did try a table saw, and this method worked better for us.
It's messy, and stinky.. And hard on the blades! We went through 5 blades, and I thought we'd have to stop.. But we ended up burning our way through the last 2 feet of track.
I'll be hopefully taking a test run this Satuday if all goes as planned.. I suspect it'll be slightly better than the stock 2" track. Hopefully it's not worse, but I can't see that happening.
The stock track had open windows in the centre, this track doesn't.. So it also should have a wee bit more floatation than the stock track.
I'll report back once I get out on snow, It definately looks better than the 2" track.
Jon
Jon
