Can someone tell me????? Will a 05' RMK 2.25 155" track fit on or in a 02' RMK w/ 2" 156" track. I'm really needing to know if there is proper clearance for the extra 1/4" and are the drivers the same or will I need to replace the drivers also?
You might check that as that 5.1 track was not offered that early. If it is a series 5.1, you will need drivers to change from the 2.52 pitch to the 2.86. I think the track would clear the front cooler, but some would say that it is not ideal to cramp that much lug into such a small hole. Your call.
It is better to go with a camoplast challenger 151 x 2". It pulls a lot harder than the series 3 or 4 that you probably already have. You will want to wear a next brace, to prevent the reverse whiplash condition.
