Track Swap...
J
jols
New member
Anybody know where i can get detailed instructions on how to swap the track on my assault or is it pretty straight forward??
Loosen track tension, collapse springs, remove 4 skid bolts, left side driveshaft bolts. Remove can, chaincase cover, chain and lower sprocket. Remove drive shaft then reverse the process for assembly.
Yep, and if you search there were some detailed instructions about a month ago in the Polaris section. It helps to have two people to move the track and drive shaft.
