Does anyone have detailed instructions ,maybe with photo's that they can pass along to me for track removal ? I'm new to Arctic Cat's ,switching over from many years of riding Polaris ,thanks for the help.
This is the easiest way to do it. You might have to wrestle with the tack a bit to clear the tunnel on the dropped side, but can be done alone. I have done it a few time this way.When you remove the diamond drive there is one nut behind a piece of rubber. Make sure you remove the rubber to get at this nut. Also on the brake caliper side if you do not want to deal with that big locknut you can take off the 6 or 7 seven bolts that hold the brake caliper on. They are on the inside of the tunnel by the track drivers. This will allow you to tip your drivers enough to get the track out.
Any tips to get the double bearings in the brakehousing out?
