Track on 04 Rev
T
Tackbtch
ACCOUNT CLOSED
Sled is running a 2 inch track, can the sled run a 2.5 inch track from a 06 Rev? With out major modification, Dino
2.5" from a 06 Rev????
If it's a stock track then it's not a 2.5" it's a 2.25"
You probably have 9 tooth drivers in which the 2.25" should fit.
If it is a 2.5" with a 3.0 pitch then you'll have to run 7 tooth drivers.
The wifes 06 X 144-16 is a 2.5...or just barely under that measurement. ??? Changing drivers is ok, I just didn't know if the bulkhead would allow the larger track. Thanks Dino
