Track Change on M7
i just pull the skid and the d/d,use a punch to remove the lock ring on the
brake rotor,remove the rotor and drivers.takes about 1.5 hrs after you align the track
Track change
Take pictures when dissassembling this will help if you have problems.
This is how I did it.
1. lift back of sled and remove skid
2. remove long bolt and locking nut from brake rotor " I used a punch to remove large lock nut."
3. remove driven clutch and diamond drive.
4. Now inside the tunnel remove the nuts holding the brake rotor " You just nead to move the rotor far enough out of the way to pull out the driver and track.
5. Make sure to put track in the right direction "there are arrows on the track
6. Also when installing the large nut on rotor after you tighten it with your punch there is a slot that you nead punch the nut so it does not back off.
7. Install rear skid
You will nead to tork the long bolt on rotor side,and driven clutch bolt
If you nead more pics let me know.
