Track alignment problem
A
airmanf
Recently I installed a holz two wheel kit on my 08 154 and when I get the alignment right the track tension is looser on one side than the other. Each time I adjust it I'll spin the track several time to set the tracking. Am I doing something wrong or did I maybe bend something?
Thanks in advance
What do you do for track alignment? Have you measured center of each side to a fixed location further towards the front of the suspension? If the rails are bent or something you should be able to eye ball them looking down them to see a wobble or something. But if your sure your doing everything correct start taking measurments and see if something doesnt add up right. Do you have the axle assembly installed right? I am trying to think but i cant remember if the peice from the axle that slides in the rail has an offset hole or is it dead center? Anyhow good luck..
