TRA 3 Primary Clutch
eddy
FS TRA 3 Primary, in good shape with tight sliders, center bushings and o-rings. Will include the parts to do a rebuild: Center shaft bushings, flyweight bushings, nuts, clips, pins etc. $125 shipped to your door in USA. The rebuild parts are over $100 by themselves!
TRA 3
$125 shipped USA primary w/ the extra parts - Clutch in good shape for bolt on service the way it comes!
Any Idea what ramps are on it? Spring? Toying with the idea of putting it on my 600ho but Not sure how much I need to change to get it to function. Thanks
600HO
Should be fairly close, might need a different spring, might have one. Springs are cheap! Remove the set screws, Drill out the pins? These things are very tunable. For the 600: I have a new Carlisle XS806 belt I will throw in for $35 to make the deal.
TRA
It has the through bolt to mount the arms (600 uses a pin held down with two bolts), hollow pins with set screws and I am going to guess 299 or 300 ramps with a violet/yellow spring.
Might be very close to what you need. The sets screws may be your friend!
