TPS voltage
Couldn't find a section for the F series sleds so I put this question here. Hope thats ok.
I have a 2007 AC F5 with a bog on take off but once I hit the mid range it seems to work fine. I checked for air leaks between the throttle bodies and engine and things seem to be fine there also. I also cleaned the throttle bodies and changed spark plugs. Still bogs. I have a TPS tester so I took a voltage reading of the TPS. The low reading is 0.7v and the WOT was 3.4v. I am not familiar with Cats but I know that the optimum WOT voltage for polaris is 4v. Would that be the same for the Cats.
stomper is online now Report Post
( 2005 - 2014 ) 500 cc EFI running rich... ?
Still bogs.
Wife has a sled with the same engine with the same problem.
Running rich and bogs 0~50 % throttle opening.
