I want to check my tps as part of preseason maintenance. After reading every thread I could find about how to do it, it seems that most people use a homemade tester that uses a 9 volt battery with a resister to bring it to 5 volts. Another option is to power up the system with a 12 volt battery and then back probe the tps plug and check it that way. Even though the second way seems less common it seems like it would be better because it uses the sleds own system to feed the 5 volts to the tps and eliminates some of the complexity of using the 9 volt battery and resistor. Anyone with some experience have an opinion?
