Tps setting
So my sled would not go into reverse. Most people pointed out a tps issue could be the culprit. So I use my tps tester and get like 2.52v at closed. Well, that ain't right. Mess with all the adjustments and can only get it down to 1.05v.
So I take the tps off and hook it up and get .23v with only the tester connected.
I took another tps and checked it and get .00v, unlike the .23v on the other one. Anyone seen this before?
Let's hope it cures my reverse issues.
Hey guys, can I adjust the tps on the sled ('05 900RMK), or do I need to pull the throttle bodies?
I have done it on the machine before and honestly it is a PITA. You are better off pulling them and doing it on the bench but lay a towel down because dropping the set screw and/or sping down under your motor is a bummer.
