This idea sounds crazy and even looks like there is no way it will work BUT IT WORKS GREAT. Only thing that may be a issue is that u need another sled to ride on.There's many ways to tow out a sled and I've seen almost all of them work. Obviously first take the belt off so the track runs free. I'm a firm believer in tying both ski loops of the dead machine to the bumper of the towing machine. Need to tie it so tight that the tips of the skis on the dead machine are starting to lift off the ground. When tied tight like that it follows like a hitched trailer and can't run into the towed sled if you stop suddenly. My $.02.
Sent from my E6810 using Tapatalk
Y is the doo always pulling the poo?I have my own version.
I use a piece of fuel filler hose to feed mule tape through. If just on a road you can tie off to a ski loop and then back to the spindle. If you need to pull it centered, a small tree works good and notch it for the ski loops to lock into before tying off. This is stored under the seat.
If that isn't enough, I carry a Tow-Buddy for the rear of the sled. I helped drag this sled out as a rear anchor for the nasty downhill runs since the sled had no brake (Quick-Drive belt issue). This is carried just behind the seat.
I've heard of the ski loops breaking when you tie to them. If you think about it, the towing force also makes the skis dig a little instead of float and articulate like they are supposed to. And tieing to one ski makes the dead sled track to the side putting unnecessary load and resistance on the tow sled. Using just a rope works but it's real hard to control the slack and when it slams taught it will immediately break a Polaris bumper
