Torsional clutch conversion kits and electronic reverse
Mntryder
Looking at adding a torsional kit to a 09 M8.
Have heard that the cutlers is the only one that will work with the new reverse. Is this true?
I had a RKT on an 07 and was happy with it.
Any experiences with the D&D, BMP, RKT or others kits with 2009 or 2010 sleds ?
Just want to know that reverse will work whenever I hit the button.
Thanks
Thanks
Im sure that is not true. I use the CPC and its good. I would use RKT just the same
as long as your secondary is closed/ backshifted all the way when you engage reverse RKT will work fine. as far as forward it works aswesome!
