torque specs for cap screw that holds secondary on?
White Rad
can someone confirm these torque specs i wrote down... it snowing and i need to go sledin!!!!
for the 9/16in cap screw that holds the secondary to the driven shaft: 32ft/lbs
and for the 1/2in 12pt that holds the primary to the crank: 55ft/lbs
thanks, ryaN
55 is right for the primary....don't know the number for the secondary, i just use moderate tight, so i would think 30 would be about right.....on the primary, after you torque it, run it on a stand for a minute or so...then re-torque the primary, it will cinch down a little more and you should be good..:)
thanx guys i got to run it for a few min. on some real snow and then re-torque. runs very strong w/ the new weights, man they were off on the 07' rips now though!
