I was going through some of notes today and thought this wold be a good topic for those of us that are replacing pistons in the 800 CFI-2 Pro-RMK. I install MTNTK kits in theses sleds. But this topic is about ring end gap.
I have been noticing something through the evolution of the 800 CFI 's. Both the 4 injector (Dragon) and 2 injector (Pro).
Either the cylinders have been tightening up as they get newer in model year, or the rings in the MTNTK kit are just a tad longer. I am guessing the cylinders are tightening up just a tad since the stock pistons seem to be just a tad tighter in the bore as well.
The kit's I put together back in 2010-2011, the rings would have about 0.022" +/- 0.002". I Didn't have to file the rings.
The kit's I have installed since 2012, have been tighter, down to as tight as 0.016" and have required filing to bring up to a minimum of 0.022". I've been setting mine up to 0.024"
Out of all of the kit's I have installed, we have not had one comeback.
It doesn't matter whose kit you install, you must check this. If you don't, then you will likely have a problem.
