Top-End Piston Pin Needle Bearings
J
jTrue
Anyone know of a source for aftermarket roller bearings? 75.00 for a set of (2) bearings and (4) washers seems crazy. I thought the Wiseco kit I purchased came with them like the other kits, but no such luck(should of made sure).
You can buy them from wiseco for a lot less, but I really think the cat ones are better quality.The thrust washers I think you have to buy from cat.
Should have bought SPI pistons. They are cast and come with bearings. Make sure you warm those pistons up REALLY good every time you ride that sled or you will get a cold seize.
I have not seen any piston kits that come with the thrust washers or bearings. Rings and wrist pin are all I've ever seen. Dennis Kirk and Shade Tree both sell just the bearing, usually the washers are good for several rebuilds.
Now that I think about it your right. I ordered bearings when I ordered pistons.
