Just wondering if anyone has had this problem. When I put the throttle to the bar from 3/4 throttle it bogs to about 6500 rpm for 2 seconds and then picks back up. Just wondering if anyone could give me some clues as to what this could be. Thanks
ride it again, use the recorder and make sure you arnt hitting the rev limiter..the stock tach cant keep up with the motor and will show 800-8100 rpmon acceleration when in fact it is hitting 84-8500 rpm and hitting the limiter..if thats not it.. .the 11's(I assume this is an 11) had some issues with injectors that would cutout at full throttle...also check the throttle freeplay, the powervalves and make sure they are clean, and thats about all I can think of right now...
