tools
Sooo! I think you have a very good start on your tools but I believe you should add a few more . To that list I would add 1/2, 9/16 and you need 2 of each and same with your metric so you can hold both side of a bolt. wrenches should be box end with open end! Then i wrap duct tape around my philips screw driver as close to the handle as I can till it's about 1 and 1/4 inch diameter that way you carry alot because of the small diameter it starts out at instead of the regular roll you buy. Also spring hook which I made using an old phillips screw driver but you have to know how to bend it to make it work right and have a torch to do it, I don't like a lot of the one's you can buy. hose clamps ,electric tape, safety wire and regular wire , a few of the more common 1/4 and 3/8 bolts and nuts along with the metrics sizes they are using now.Also some washer's and both regular and fender size! I use a bank money bag to hold the parts and old polaris tool roll for the tools. please take out of sled and let dry after each ride. If the weight is and issue for you just think about not being able to fix something and ruining your or friends ride because you can't fix it . One other thing with what you have and maybe what you buddies have for tools you can fix about anything. Happy Sledding!
