I
Insaneboltrounder/sjohns
I saw a ad for toms turbo setup.... it says 5600 and you get 25-30 hp? Tell me this is a typo
early in the year aerocharger was claiming 190hp at 8lbs of boost in their advertiseing. people complained that it wasn't much for the money.
Now the are claiming they dyno 240hp at 7psi.
That is pretty amazing. the few 800r' dyno sheets that I have seen were 220hp at 10lbs of boost with a garrett turbo. Bryce had a post somewhere that a xp makes about 8hp per lb of boost. He said the xr1200 made the most hp per lb of boost of any sled they have worked on. 9hp per lb of boost. I believe bryce.
another thing I laugh about is that last year their were posts from aerocharger that turbo's were getting destroyed because they were runing over 10lbs of boost and overspooling the turbo. aerocharger would not warranty them because they were overspooling the turbo. Several were posting that their aerocharger turbos were failing at 12psi.
their was a post on snow and mud where they were saying 10-12 was the highest for maximum engine durability. they didn't mention their turbo's will not stay together over 10psi.
cut and past from some posts by aerocharger_brad on snow and mud.
"Dyno testing was all done at 7psi and made 240hp even at 6psi I would estimate 231hp. "
so only 9hp per lb of boost?? Must of made 177hp stock on this dyno.
"We do believe 12psi will be the highest we will want to run and most should stay at 10psi for maximum durability of the engine."
post located here:
http://www.snowandmud.com/forum/460/800-e-tec-turbo-systems-37830-2.html
Not sure even where to start on this. 190hp at 8psi may have been the 600c we were working with. The 800 makes 240hp at 7 psi per the race dept.
Designed for the 2011 Summit E-TEC. The kit is a plug and play. It adds a consistent 25 to 30 horse power.
funny though , the guy that makes the turbo says 80HP and the guy that fabs the kit says 30
who are you gonna believe ?
i want to say its a typo on toms part but its posted like 4 times all over the page ?
check it out for yourself ...
http://www.shoptomssnowmobile.com/E-TEC-Turbo-Kit-detail.htm?productId=-287654&catalogId=-844&fpg=1
Yah and RK Tek Pistons make an extra 15 horse! NOT!!!!
And SLP pipes make 10 extra HP in the mid...NOT
And Reeds add an extra 5 HP.....NOT
The aerocharger E-tech on 7 lbs of boost makes 240 hp.....
the new pro is alot more effecient in making power so is the etec.
my personal opinon ( and i am not bashing here) is the numbers are corrected on the dyno for absoulutes. i could be wrong i have not seen a dyno sheet yet but that would be my guess.
Or there could be a new size of turbo out that is flowing a ton more air.
Is there any way that you guys at aerocharger can teach us something that we don't know or understand how you got those numbers. brp race dept did the runs so there has got to be a sheet some where.
