T
trinitypowder
I got a phone call from Tom almost two weeks ago about my suspension. Tom said "I saw on Snowest that you had been having some problems with the paint coming off of your upper shock mount on the rear arm. We have identified the problem. When Fox sent us the Evol R shocks for the rear, they forgot to tell me that they put a bump stop inside the shock. It measures .857 of an inch and under full compression it is .50 of an inch. That half inch of travel is the problem. The shock is bottoming out before the suspension does. We have designed bump stops into the suspension already, so the Fox bump stop is what is causing the arms to fail. So far we have had 3 fail. It's an easy fix though. Pull your shock, put it in a vice, release the MAIN chamber air pressure and unscrew the shock body. Then take a straight edge and cut the bump stop out. I have done 4-5 on the sleds, but it's easier to put it in a vise. I'm glad we found the problem and am sorry for the issues you've been having. I will send you a new rear arm, that's no problem. We have added some additional bracing to the uppershock mount, although now that we know what the problem is, it really doesn't need it. But since yours may have stretched, I'll send you a new one. Thanks again and I'm sorry for the problems. Call me if you need anything. Thanks Ike". So there you have it. I have the new arm and it is BEEFED UP significantly. It looks like my 3 year old welded it, but it does look stronger. This arm also came fully assembled with the top roller and bump stops installed. I just got a PM from a guy that just had his fail and it did ALOT OF DAMAGE. After hearing from Tom, I believe he's the kind of guy that will take care of it. Here's a pic of me "pounding" the old arm, with the bump stop removed. The arm is still ok. And here's a pic of the new arm.
