F
Flatlander44
Is there any tools that really help with engine removal? Or any tips? Thanks
Long extensions and wobble sockets.
basic hand tools? i dont get the question? air tools, i love my snap-on 3/8 electric impact
Drill four holes in the bottom (in line with the four engine strap bolts and a size that is pluggable with electrical box knockout plugs or rubber grommet style plugs) to access the engine strap bolts and then you do not have to monkey with all the others. The main four and the torque arm bolt and fuel, electrical, intake and exhaust. Can be done in far less than an hour, without air / electric impact tools. It is far easier to re-align the engine this way as well. As all the engine mounts are in their natural neutral state.
Most people just F stuff up with an impact anyway. If you really care about quality work and proper fit up and torque, you won't use them either. Just my 2 cents.
i guess if you dont know how to use am impact you shouldnt really call yourself a mechanic. just my 2 cents
I have been making my living as a industrial Mechanic / Welder / Machinist for 30 plus years, and I know how to use one and when they are appropriate.
They are great for stubborn disassembly tasks, but everything should be clean and lubricated going back together and should install with your fingers and a final torque, so no impact is needed.
I'm not your flat rate, minimum wage, dealer certified parts changer. FWIW
So just to be clear.......You wont use an impact but you DO drill four 1"+ size holes into the bulkhead?
If you did that to my sled you would be putting a new bulkhead in it.
Just my 2 cents. Eric
Fuel line connection tool
