Honing
If you decide to hone it I wouldn't recommend a ball hone. run it down to your local small engine shop and have it honed with a rigid hone with diamond stones .
Ditto -
It isn't a bad idea to ask the machine shop if they have Diamond stones for plated cylinders & what grit they all have.
Car shops & small engine shops that are behind the times for plated cylinders will most often say they have the right stones because most believe they do because their boss told them what conventional stone to use........and there is NOT a conventional stone that works.
These stones are expensive, and many shops do not know plated cyls require special wear shoes & diamond, or will not spend the money.
conventional stones & ball hones will not work on plated cylinders, it will run but it will never give you full performance with poor ring cut in.
The vendor you bought the pistons from should supply you with the correct stone grit........then call Sunnen products and get the part number.
The part number will vary depending on the type holder the shop uses,
AN - is most common for most shops with old style sunnen holders.
And Polaris Mono cylinders should always be honed with a base & cylinder head torque plate installed torqued between 37 & 50 ft lbs depending if your motor is stock, or modified or has a turbo.
The Polaris Mono cylinder distorts between .0005 to .002 thou depending on what torque spec you use.
There is a bit of a learning curve with every motor, and this small block requires lots of little details to make it run hard.
Dan
