tm8 top end bog.. help
MikeM1000
i just bought a 07 TM8 and it started bogging and loosing power after being on boost for a short climb.. runs good then bogs and looses power, only making 1100-1150 deg on pyro.. boondocker box says max psi 8.0, peak 10.4, its a race gas turbo straight 110 i turned the boost control up a few (5ish) clicks but doesnt gain boost on boondocker, and only able to make 7700rpm, buying a actual boost gauge to make sure thats correct ... anyone have any ideas, it ran good at first then just started bogging
sound like you clutching is off might want to try more weight in primary could be fuel but would check clutching first mine sled was doing the same thing added some weight runs like a train now
