Sled is a 2010 M8 OVS Tial kit. I just put on a stock 2010 HO head, larger compressor housing and the OVS timing module. I'm running 50/50 91/112 mix and was at 7k feet today.
I wanted to get out today and get my PL box dialed in. I didn't get the chance to change anything due to the sled would die every time I'd give it full throttle. When I'd give it full throttle, the motor would shut off, RPM's would disappear on my gauge (I'll I could see was altitude and odometer) no codes, no temp light, nothing.
Sled would fire up afterward and idle and take off ok, but each time I'd get on the gas it would shut off. After the 3rd time I loaded it back up and figured I'd call OVS and see what they suggested.
So I was watching the temp light b/c I know I took more coolant out of the sled when I changed the head than what I put back in. After I switched the head I filled the bottle back up, lifted the front end and let the sled idle until I could fill the rear cooler getting warm. I went through 5 or 6 cycles like that before I took it out.
Anyhow, I only went 2 miles before I loaded it up. The sled ran great prior to these changes. I'm wondering if my issues have something to do with the new head or the timing key?
Any help is appreciated. Thanks,
