Titanium M-10 Springs
I have two rear spring setups for a m-10. One has an aluminum adjuster and the other has a plastic adjuster. Both setups are for a 200lb rider. I also have one titanium front arm spring. These springs are extremly light and save a ton of weight over the huge stock steel springs.call with questions 425-577-8587 Jesse Ingmire
$250 for the aluminum setup
$250 for plastic setup
$150 for front arm spring
I couldnt tell you the excact weight savings but i can tell you its significant. Stock steel M-10 springs weigh a ton!!! These hardley weigh anything and they ride better too
