Rotating the tires on my Megacab today and took down some readings. It appears to me that the rear is suffering from over inflation and the front could have a slight aligment issue.
Front Left - 54psi, TD middle - .397, outside - .346, inside - .370.
Front Right - 54psi, TD middle - .383, outside - .384, inside - .345.
Left rear - 54psi, TD middle - .195, outside - .345, inside - .356.
Right rear - 54psi, TD middle - .203, outside - .347, inside - .354.
Door says to run 60psi in the front and 45 or 70 in the rear. (light load or max load).
Most of my miles are highway miles empty or with a 3000lb open trailer with about 600lbs tongue weight. Occasionally I have my 4 place enclosed and 4 sleds, probably 4-6 weekends/winter. Truck has just under 19k on it and the tires are the stock BF Goodrich all terrains. Very little gravel, no burnouts.
Tire experts..... should I drop the rear tire pressure to 45 and raise the front to 60?
