I wanted to start a long running thread about, the things people know and do that help even a little.
here is one to get started.
painting with aerosol cans.
we all know we want the two stage paint look and durability but its tough to get out of a can.
here are two things
1) Use Duli-color paint (no I dont own stock) it simply is the best paint in a can. I painted 1/4 of a blazer with 3 cans for a short term emergency winter fix and 5 years later it still on there looking good.
2) the only, I best primer I found out of a can is dupli-color self etching primer, everything pales in comparison that I have tried. try it you'll see.
3) okay here is "the tip" whenever you paint anything use a heat gun and warm the part, to something like 120 °F next use the heat gun to heat the paint can to about the same, it should be warm or a little more than warm in your hand. shake it regularly and you can actually feel how the heat changes the viscosity of the paint and allows it to be sprayed much easier.
I know you should never heat an aerosol can and all the safety warnings and stuff, but use your head it works.
what do you have!!!
Spomey
here are two things
what do you have!!!
Spomey
