tips for separating exhaust
noob
Replacing tunnel on my tapex, and have the four bolts out between exhaust flange and turbo unit. but it aint coming apart. the next section ain't coming apart either midway down the tunnel. any ideas or tips.
Is this a mcxpress? I would use a rubber malet (sp?) and knock the exhaust on the turbo a few times, should come loose. With the others I would heat up a little bit with a torch and see if that works.
that worked. thanx
