Timbersled Mountain Tamer
lancelarue
Installed the Timber Sled rear suspension in the shop sled to try out here in Valdez conditions.
06' Summit 151 X
860 Built by MKS TEC LLC.
Slp pipe
07' airbox
Boyeson Rad valves
2 mm. oversize rollers Thunder arms 100X260 spring in Primary
Paragon Secondary 58* helix Duane's spring
Pre-mix
Went out last night first ride with this suspension, going to be interesting!! Great ride, & I can tell the difference keeping the front end down right off. This has been the problem with these sleds from the beginning in this heavy snow here running power. I'll have some more info as I get some more testing . Mike
you will LOVE the timbersled suspension!!!! here is a cute little trick for setting it up perfectly...
