F
freeflorider
Ill keep this a short as possible,
picked up a turbo nytro with a timersled skid that has fox floats. First ride suspension sagged to the ground??? added 150lbs of air didn't do much. Called t.s and was advised to move back shock up to front mount ,done. five min up the trail the shock mount snaps.
I had a new shaft made..3/4 stainless, installed in back hole with 145lbs in it, sagged to the ground when riding. moved it to the front hole and it seemed to fix the problem, next day went for a ride and at the end of the day I noticed the shaft is bent wtf.
Is my shock done? dumped all the air out and on the ground it still has some resistance to it. (but won't hold the suspension up)
Reinstalled it with 100lbs and layer over the back end to collapse the skid, the suspension goes down to all most bottoming out. shock problem???if i add more air it bends the shaft.
Is there a proper shock for the rear, its just a float shock and seams to function fine but am I bottoming out to bend this or is the shock locking up.
can't figure this out...help
