Throttle sensor?
C
cr187
New member
Has anyone bypassed the sensor in the throttle block? I unplugged it and now it won't rev up. Thoughts?
Dismantle the factory plastic throttle block, pull out the throttle safety switch. Plug the TSS back into the wiring harness and tie wrap the switch at the end of it in the down position. Now reroute the TSS wiring under the hood and tie wrap out of the way somewhere. Done
Why can't u just unplug it?
Because the ecu needs to read a resistance across the switch. If it doesnt get the reading it needs it will go into limp mode. Limp mode is what youre seeing when the sled bogs just prior to engagement.
Thawed out and yes it worked fine last week when I rode it unplugged
Well bud I'm really not sure what to tell ya. It ain't supposed to run unplugged, then again it's also supposed to keep the sled from ghost riding away when the throttle is stuck too and I've seen personally that it doesn't always prevent that from happening either.
X2 It should not have run unplugged. Not sure what you have going on there.
