throttle flame out (RX1 turbo)
T
Thunderguy BOOSTED
Ok, iv searched and searched but could not really find anything....!
So throttle flame out? I never even knew there was such a thing... So guy please HELP!:boom:
Flameout is basically just the sled flooding out when chopping the throttle or letting off from wot. My rearmount didn't have any flame out at all. But my Boondocker rx-1 did. You can solve it with two bov's or one big one. It also has to do with setting your float bowl levels, but I'm guessing someone has already done that on your sled. Ride and see if its an issue. My experience is that the rearmounts don't have as much of a problem with it.
Before you get stressed out try your sled first, it may not be that bad. your a young kid with a wicked sled and have been pumped for a year to get a turbo and now you have one so dont get stressed out because your sled MAY have flame out. That sled will kill any sled you have had in the past with or with out the issue So when the time comes if its there then worry about it, the rx1 has been around for ever it will be a easy fix buddy. cheers
flame out is something that you will easily adapt your riding style to. Once u get used to the sled and not chopping the throttle and just easing out flame out will never be a problem. ur thumb will adapt to the throttle couple after u put some miles on that beast.
yep... Mine was setup wrong, so it was pretty sensetive and would flame out pretty easy, it was due to my turbo system I built, but either way, I had it pretty bad if you chopped from WOT, it would die. I got really used to it and had almost no issues on a sled thats really sensetive. You just get used to not chopping it like a 2 stroker.
Great advice. This ain't gonna be no 2 stroke, riding style is totally different. Give that thing some respect for a while till you get used to it cause its going to work you.
M5
