C
constech
My 08 Nytro running an MPI Stage three supercharger geared down to 15 PSI at full throttle. I have a cut out when throttle is applied. If I very slowly apply throttle I can sometimes avoid the cut out. also at higher throttle when adding throttle will get the same cut out, sometimes it recovers and 1 in 10 times it stalls. Once through this cut out it runs awesome. I called MPI and they had me adjust the accelorator pump settings on my controller, but doesnt seem to help. I heard it can be the battery and since I had a light weight slightly under powered battery I changed it back to stock with no change. When it is started with no throttle it runs with a loaded up sounding bog for several seconds before it cleans out, If you can help me out I would sure appreciate it.
