Throttle calibration question on PCV...
J
jols
New member
So where is everybody getting the percentage readout on the screen when calibrating the throttle?? (Ex. 0% - 100%). I am only getting the minimum voltage and maximum voltage readings. The bar that slides on the bottom of the graph fully opens when I fully open the throttle but there is no percentage number.
My readings are:
Minimum voltage= 0.913 Volts
Maximum voltage= 4.153 Volts
Is this correct?? Any help would be greatly appriciated!!
I did that before I even started the calibration.... Like the instructions say to do... haha
Your throttle percentage is in the MAIN window when you open the software under the RPMs.
The numbers you have are right. But, I'd say you need to have your tps adjusted the idle voltage should be .930 on an 800 and .950 on a 600 or 700. Maybe its alright if you're not having problems but mine was down where yours is at and it would barely idle and it wouldn't go into reverse. Runs great after adjusting the tps.
I had the same problem make sure you download the latest version of software and firmware. I had to install the latest firmware about 6 times for some reason it would not take right away and once the firmware took everything was good!
Hope this helps.
