I'm trying to do a get in and get out tps setting job on an 08 d8 dragon. sled will be brought inside to work on then removed hopefully in a couple hours.
Airbox is out.
Is this the procedure for removing throttle body?
Airbox is out.
- remove coolant lines to TB and plug
- loosen clamp on clutch side boot through window under clutch
- pull off assembly
- unplug TPS
- undo throttle cable
