throttle, attachment on 02, 700
I broke the top of the throttle lever, and the screw/ rivet does not have any visible way to remove it. No hex, no self threading,,, anywone know how they get off so I can replace it?
Not sure what it is that you're looking at???
What type and year sled?
What part broke?
Flipper?
Throttle block with the kill switch?
Everything comes apart on the throttle block and flipper.
EDIT: just saw the title:rolleyes: sorry!
everything on that sled around the throttle block comes apart.
There is a hole under and in front of the kill switch and WAAAAy up inside is an allen screw.
You probably can't see it but start stuffing allen wrenches into it until you find the right size.
You will have to take off your grip and heater before you can slide the throttle block off the bars.
All the allen screw does is lock the block in place on the bar. you have to slide it off the end.
It does NOT split in two.
