Thoughts/opinions on 800 rebuild
Blainelukens
My GF is on my old 16 t3 800 Etec, died on the trail last weekend. It has 4800 miles, warranty was up at the end of January. Pulled the motor thinking I was going to get away with just doing a top end on it. PTO cylinder started falling apart and cracked the head, I suspect it was running lean do to a vacuum leak.The plan was to get a reman mono head from millennium tech and put a top end in it. This was going to be roughly $1k to rebuild myself, however I checked the runout of the crank and its F-ed like .025. I can see the wobble when I spin the crank on the PTO side. My thought is bent crank as the bearings feel tight. Would like to get it back in operation sooner than later, as we typically ride till June. At this point I'm thinking a reman long block from ski doo. My dealer quoted me $2100 plus core.
Anyone have any experience? Thoughts/opinions on what is the most cost effective route?
I don't think I can rebuild this for much cheaper than $2100. I do not want to use aftermarket parts or do a big bore. Want to have a reliable 800 Etec again
Get SD long block IMO, I'm sure you will find they are not reman. but new. Check crank run out when you get it. Question the warranty as I believe it is one year if dealer installs ?? Good dealer can make it work if you install and keep an eye on crank runout at 11month's as it is easy warranty if over spec.
I ended up ordering a new motor from Doo, sent the injectors off to have them gone through. Now it is just the whole waiting game, definitely have my fingers crossed that it will get rode again this season. Typically our last ride is Memorial Day weekend ?
