Ok, phase one of the diet is done! -30 lbs...
For those interested in weight loss here is a summary
Start:2012 PC Sno Pro. coolant full, oil in middle of sight glass, chain case same, spash of fuel in tank, Powder Pro's, 38" front end, handguards, knee pads, A/C skid plate, touring bumper = 503lbs.
1) Speedwerx can -12lbs= 491 lbs
2) BDX oil delete, shorten cooler, 2013 parts incl. drilled brake disc, motor plates, TCL and fluids same as above -21lbs= 470 lbs
3) added CE 2.5" track and scratchers + 3lbs= 473lbs.
All weights +/- 1 lb.
How much work is it? PLENTY!!! Started last week and put about 10 hours I guess total. Worth it? I hope so and a bonus should be the CE track and skid drop.
As far as guys asking if they can cut and TIG weld the exchanger in the tunnel, I think good luck on that one!
I am going to build up a piece of aluminum to cover the holes in the tunnel extension. I will press a bead down the center for the taillight wiring and also will give it more strength. Thought about swapping out the rear tunnel. Looks like way too many rivets to be any fun and many are those serious looking ones...
To summarize the process for the exchanger:
1)Remove track (there is a good article on arcticchat)
2)Remove fuel tank braces, fuel tank
3)Drill out rivets on top of tunnel
4) there are two torx headed bolts under the tank brace brackets, remove them
5) remove mag side mount bolt through tab on exchanger
6) remove lower coolant hose RH side, drain coolant into pan
7) remove coolant filler hose
8) remove TCL
9) remove LH side brace from tunnel/exchanger to front frame brace
10) remove two front bolts than go through frame and lower corners of the exchanger
11) remove tow screw that go through exchanger and into chaincase (inside of tunnel)
12) drill out three rivets under heat tape at front of tunnel/ into exchanger
13)drill out 9 rivets on LH side of exchanger (not the rivets that hold the two tunnel layer together!)
14) drill out 5 rivets on RH side of exchanger.
15) make sure the back side off all rivets are removed!
16) remove exchanger assy byt dropping the bumper end down first and wiggle it out of the tunnel. I had the sled up on a lift.
NOTE: Arctic Cat rivets have either a steel or stainless steel body. I would recommend getting them for A/C as I found none with steel bodies at any of the local hardware stores although there are not a lot to choose from.
Reverse steps to reinstall!
I have more pics if you are interested PM me.
