D
DallanC
New member
This carb bog is driving me nuts!!! 92 PhazerII, sled ran flawlessly for years until this year when I started having no end of problems. The sled has a horrible bog just above idle. If you feather the throttle or flip the choke on off you can get it past the bog... after 3k RPM its runs perfect, screaming around the hills. Soon as you stop its a bear to get over the bog again. I cant tell if its running rich or lean during this bog. If you give too much throttle it will stall and wont restart easily unless you choke it (doesnt that mean its lean? If its dieing because its too rich, choke would make it worse wouldnt it???). The sled will happily idle all day long.
Anyway out riding again today and I had a idea... I made a small movie of the bog with my digital camera that hopefully someone can view, and give me ideas of what in the hell I can do to fix it.
2.5 mb. Click the link then select "Save As" and save it to your desktop, then play it.
http://www.huntingnut.com/images/temp/snowday/phazerbog.wmv
Please, someone out there has to have an idea of the cause is... /beg
-DallanC
-DallanC
