i would just repair the wires no need to buy a new sensor then ride it and see if you get a check engine light. the ecu would be the component damaged by the shorting wires but i doubt it would because the ecu isn't sending power on the wires just looking at the resistance between the wires.
the wires to the temp sensor don't need a fuse.
as i explained earlier the computer is just looking at the resistance no power on the wires shorting should not affect the ecu.
