First off just want to say the Brice and Josh of Turbo Performance have been great to work with. Customer service is top notch. When I was so frustrated with my sled, they told me to drop it off and they went threw it all,and took it out and rode it all for free.
I just want to let guys know my experience so that maybe they don't have to go threw what I have. I got my kit back in November sometime. I put it on myself. It took me a few days. Instructions I give an 5 put of 10. I think there may have been a few pages missing. Brice was great to answer calls and help out. I got the kit with the 6 pound spring in the waste gate. Also got the boost tee to be able to adjust the boost up. Decided to go with the air/fuel gauge. The first set of gauges they sent lasted one ride. The boost and fuel pressure ones. So Brice sent me out some new autometer ones. I went from the 320 mains jets to the 310's that they recommend. Keep the 15 pilot jets. Fuel screw the same. I started out running 100 avgas. I ride from 6500 feet at the parking lot to 9500 feet.
Well the first time I went out it was really rich in the middle and good on the top. The first two pull had the check engine light flash on then go off. It was running 13.3 F/A So Truned the power jet out a half a turn. Anything under 13 A/F the engine light would not come on. So ran it at 12.2 I tried turning the boost up to 8. Really could not tell where it ended up at. The gauge was flickering from 5 to 10. Made a few more pulls until it got dark. I was excited about it at this time. This is going to be fun. Sorry to say that was the last time I had any good feelings about a turbo xp.
Well after taking it out 6- 7 more times tryin different pilot jets, niddle setting, and fuel screws settings to get the thing to run. Lots of calls to Brice. It would not idle or run at all. It was very very frustrating. One thing that I did learn is that the sled does bog bad when you turn to the right. The only fix for this is some kind of home made intake for the turbo. I guess Turbo performance has one that they are coming out with. So now add that to the cost of the kit. This is the point that I said this turbo thing is not worth it. I did not get the kit to have to have this many problems with it. Brice said bring it up, he will go over the whole kit. Well he found a hole in the carb boot, and a blow bellow. He finally got it to idle after taking the carbs all apart, plus taking them on and off the sled three times. He also changed the vacuum line from the bottom of the case to the carbs, to try and help with the run on. So Josh went and rode it. Said it ran great. Still has the run on when it is cold. Did not turn the boost up passed 6.
So thinking sweet! It will finally work. So took it out a few days later. Idled good, started good, still had the run on on the trail. Got up into the trees and some snow. Tried turning up the boost. Wanted to get to 8 pounds. Now I was running 7g race gas 3g 91 pump gas. I keep turning the boost tee up. No change in the boost. That sucks. So turned to boost back all the way down. Fuel pressure was acting funny too. Josh had it set to idle at 5psi. Rode a few more miles. Something started feeling funny again. O great! Here we go again. Back to the trailer. Found one of the bellows was blown , and the fuel pressure line had a hole, as well as the boost gauge. Ok easy fix. So now it should work! Next time out made it 3 miles up the trail. Are you kidding me. Would not run, sounded like crap. Stock pipe had like a 1 1/2 foot crack. So now I learned you can't run the stock pipe on the turbo xp. Great! Wish I new that up front. So order a CPI turbo pipe. $400 said it would be ready in a week. Called them a week later and they have not even started on it. Maybe next week.
So in the mean time I weld my stock pipe up. I can't wait any longer. Want to see if this thing will finally work. So we go out riding with two guys that have XP's that are thinking of this kit. I figure this is the last time to redeem myself. Well three miles from the truck in the flats. Boost is a 6. 8 gallons race gas. Fuel screw 1 1/2 turns out. A/F 10-11.5 BOOM! I loss power and the thing sounds like my pipe cracked again. So I get back to the shop. Right cylinder 0 compression. Left one is 85 down from 120. So started taking it all apart. Looks good as far as rich or lean. Part of the right piston ring is gone, which put a big dent in the exhust side of the cylinder. Left piston looks like something came through the intake. Scuffing on the intake side of the piston. Cylinders are toast. So then looked into the turbo. The piston ring took out the blades of the turbo.
So here is the damage
Turbo kit 5200.00
New card boots 190.00 for two. Must replace when you put the kit on.
Turbo pipe 400.00 a must.
New two ring pistons, and top end kit. 360.00
Fix cylinder 380.00
New blades for turbo. 380.00
New intake to stop the bog $?
Would I recommend this kit to someone else. No!!! The Turbo boys guys are great. I think there is still a lot of thing that they need to figure out. If your one that like to tinker, and figure thing out. This will work for you. Plug and play kit? No not at all.
During all this time my brother put a Boondockers race gas turbo on his Dragon. That is a true plug a play setup. They have everything figured out to a tee. He has turned his up to 12 pounds boost no problem. That is a sweet kit! We ride with a guy the has the Boondockers turbo Pro. They just did the lestest fuel mapping update. They have that thing dialed now. I think that's the way to go. Stick with the EFI kits. Trask looks like they have a clean kit for the E-tech.
I am going to give this one more try. Put all these new parts on and see what happens. Thanks guys for all your help. Cross your finger
Cory
Turbo kit 5200.00
Fix cylinder 380.00
Cory
