The thin, dry glove thread
kidwoo
I use a finger throttle and really like thin gloves for dexterity. The problem is no thin glove I've ever used actually stays dry. From 20 dollars to just under 200, thin gloves seem synonymous with breathability which means not water proof.
Insulation is fine, as long as it's on the top, not the palm.
so what's out there?
Please enlighten, I'm tired of wasting money 'trying' new gloves by buying them.
Take a look at VO Gloves www.vogloves.com. Warmest damn glove I've ever worn! I would put them about in the middle-ish as far as bulkiness. Not bulky, but not thin.
My favorite part, is the zipper across the back of the hand! It allows you take your hands out of the gloves without having to break the seal between your coat and gloves. Also makes a good vent if your hands get too warm. :D
Ive tried motorfist, true adventure, 509, Burton for thin gloves. All get wet. Seems like with thin gloves they need to get rid of too much breathability
I use to like Mechanics gloves. The impact version for the palm padding.
Yes u get wet. They are cheap and u can carry 3more pairs in the same space one pair of bulky gloves fit. That was back when sleds actually had windshields, now they are too cold except for spring/summer riding.
Klim inversion and inversion pro are not to bad. But a lot more money. They are wind proof.
[emoji848][emoji12]
I wear a pair of cheap Harbor freight LATEX gloves (50 pairs for $8) and then put whatever over them as a winter glove. Of course thicker outer gloves for colder days
Same principle as a surfers wetsuit. Wetsuits help to preserve body heat by trapping a layer of water against the skin; this water is consequently warmed by body heat and acts as an insulator. Water conducts heat away from the body approximately 25 times more efficiently than air.
With a latex glove on first... covered by an insulated glove . . .Seems like the latex glove would make the hands sweat. Then wouldn't that make your hands colder, if this setup conducts heat away from the body?
Been using the motorfist thin glove for warm days but yeah, never stay totally dry. I've just gotten used to carrying a morning glove set, a spare day set, and then ALWAYS keep a fresh, dry, warm set for the long, cold, wet, boring drive back to the cabin. Most times I never have to use the 3rd pair.
Been using the Motorfist WOT glove, for what its worth.
The rubber glove keeps exterior moisture and wind off the hand. Inside the moisture heated by hand.
Was out Sunday in 15F weather people start having cold hands during rides gave them rubber gloves …. no more cold hands
The cost to try rubber gloves are less than a dime
Those tagear gloves look good.
I am also looking for light gloves.
Just last year a dirt bike buddy who likes to ride dirt even when temps are 20 degrees said they wear the thin latex (or whatver material) gloves under their summer riding gloves and though can be cold at first (no grip warmers), once they get going off road they are fine.
I might give the latex type gloves a try under my mx gloves and then carry a few extra pairs of light gloves. When they get too wet, I can swap to a dry pair and place the wet ones in my goggle warmer which never gets used because being so close to the pipe it will ruin the goggles if left in too long.
When you guys say latex gloves, are you talking about the turn your head and cough/surgery variety?
Preach it brother.
I need thin, not 'breathable'
I may just buy some thin liners and use them inside the hestra outer shells that I have that come with way too thick of a liner.
I'm not sure how thin you guys are thinking...but Klim Powerxross gloves are a pretty awesome glove that's not bulky. Favorite sled gloves I've had. If you are thinking think like MX gloves, those would be out.
Everyone is different on how much you sweat and under what conditions. Sweaty palms
Everyones skin excretes water. The latex or latex free glove shields out wind and cold external water.
The water trapped inside the glove next to skin is heated by body heat in the hand.
under normal or even aggressive riding
I don't always agree with donbrown but vapor barrier liners have a pretty big following amongst people who get out a lot in very cold weather. It seems odd but it works.
I have a pair of Outdoor Research Project gloves that I love on the sled. They're made for ice climbing so they have a thin and sensitive palm with lots of insulation on the back of the hand and a goretex liner. In PNW peanut butter pow they still get wet eventually but it takes a lot. Unfortunately they were replaced by the Bitterblaze glove this year which isn't nearly as sensitive or as well constructed. They are expensive but so far they've been my favorite gloves.
Definitely not buying anything from outdoor research because they give money to winter wildlands.
Colonoscopy gloves however....box o' 50. Can't beat that.
